16" Bucket for Bh600 Backhoe??
   / 16" Bucket for Bh600 Backhoe?? #1
Bacfin
Massachusetts
Kubota BX2360
Hi All,
I received my backhoe last Thursday and put in on my BX2360 over the weekend. This backhoe exceeded my expectations on power! I ordered it with the 12" bucket, but now I am thinking of getting the 16" to speed up digging. Has anyone ever used the 16" bucket on this size backhoe? Any thoughts?
Thanks,
Bruce
   / 16" Bucket for Bh600 Backhoe?? #2
I only have the 12" bucket for my BX24 but I have been very pleased with it as well. I think you would have good luck with a 16" depending on soil type obviously. I have often wanted a wide (18"-24") grading blade/bucket for the backhoe to aid in backfilling etc. I'd be interested to hear how you make out with a bigger bucket.
Matt.
   / 16" Bucket for Bh600 Backhoe?? #3
It all depends on your soil. If you are digging with ease with a 12" bucket then you probably reside in an area of very sandy loom. If you get a 16", which that hoe can handle, and change demographs to a heavier soil you can always use it as a backfill bucket. I just sold my BX with BH6000 and I have 80% clay. For me to dig with my 9" trenching bucket deeper that 3' it had to be really, really wet.
   / 16" Bucket for Bh600 Backhoe?? #4
My hoe came with a 16" bucket. I thought I'd like to also have a 12" bucket until I got a price check. Haven't bit the bullet yet.
   / 16" Bucket for Bh600 Backhoe?? #5
I use a 16" on my JD2320 and had also used a 16" on my older 17 HP JD650.
I am certain the 16" will work fine on your tractor. It may be a bit slower in hard rocky soil but hey, you can always put the 12" back on. You might want to do a price check and be sitting down when you get the answer before you put too much thought in. If the price is any thing close to a JD price and I'm sure it probably is you may be shocked.
Boy, good thing I sat down!
I checked all the local prices and as usual, all very expensive. I check online and found one 30% cheaper than anything around here. It should be here in a week. The soil in my area is great for digging. The whole area is/was all pine trees. The B layer is about 3 feet down and then all boney gravel down to 25-30 feet. I couldn't ask for better digging, so the 16" bucket will come in handy.
   / 16" Bucket for Bh600 Backhoe?? #7
370 plus the shipping! Why only 3 teeth? Is it a Gannon bucket?
   / 16" Bucket for Bh600 Backhoe?? #9
Mine came with a 16, and I had no problems digging around here.
   / 16" Bucket for Bh600 Backhoe?? #10
That's not too bad. If I remember correctly a JD bucket was about double that.
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
2002 Mack CX613 Cab & Chassis (A53117)
2002 Mack CX613...
2025 Mower King ECSSTR072 (A50123)
2025 Mower King...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A53473)
2015 Freightliner...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
