16.9-24 R1'S Anyone run this size tire on a massey Ferguson 202
   / 16.9-24 R1'S Anyone run this size tire on a massey Ferguson 202 #1
jzr756
Hello All
My massey Ferguson 202 is in need of a pair of rear tires. It currently has 14.9-24"s has anyone out there run 16.9-24 on a MF202 I'm also considering using 15" wide rims . 20191202_123256 (1).jpg
   / 16.9-24 R1'S Anyone run this size tire on a massey Ferguson 202 #2
Hello All
My massey Ferguson 202 is in need of a pair of rear tires. It currently has 14.9-24"s has anyone out there run 16.9-24 on a MF202 I'm also considering using 15" wide rims .View attachment 633793
It looks like this guy in the photo went with larger rims. Width doesn't change much but diameter can effect travel speed and torque in each gear. I like the look of bigger tires. More width would give better floatation in soft soils.
It looks like you could use new tires anyway so the additional cost of the rims are what you would need to consider. Its not a huge expense.
   / 16.9-24 R1'S Anyone run this size tire on a massey Ferguson 202 #3
I thought of doing the same with my 35 Utility (basically the same as your 202)- but -slow-travel speed and torque is more important for the work I do with the machine.
Especially low gear reverse with the 6’ snowblower.
   / 16.9-24 R1'S Anyone run this size tire on a massey Ferguson 202 #4
There were thousands of Ford industrial and utility tractors sold with 16.9x24 rears on 12” rims.
Woods LR72 72" 3pt Rake (A50774)
Woods LR72 72" 3pt...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
2002 Kountry Star Motorhome (A50324)
2002 Kountry Star...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
