155d slow throttle response
/ 155d slow throttle response
man that is show room condidtion
I know right? I've known the original owners grandson door a long time and he bought it new in 1979. Dug out a basement with it and it has been babied ever sense. And has never once sat outside. Lol. Original tires and hoses and they look brand new.
/ 155d slow throttle response #23
Well theres the problem right there, It's never been broke in correctly, A tractor needs to be in some mud occasionally be over revved, and overloaded from time to time. This is how it knows it's a tractor and not a powder puff.
Lol.
Very true. I almost feel bad for it because I'll use it like a tractor. I'll do my best to keep it nice but trust me it will be worked like a dog.
/ 155d slow throttle response #26
Nice tractor! Just be sure to watch your antifreeze mixture. That tractor does not have a water pump so the coolant ratio is critical. Installing a mechanical temp gauge would also be a really good idea.
Cool. Any pointers on thread pitch and fittings for the sensing side of the mechanical gauge?
/ 155d slow throttle response #28
I will have to check my notes but I was thinking it's metric 6? That's probably totally wrong but I know a few guys like California and Winston have it on the tip of their tounge. I have it in my notes on my phone. If they don't chime in here in a second I can check them and give it to you.
/ 155d slow throttle response #29
Hardly. I posted details long ago when I researched for my own use, now can't remember, or find the post.
The oil fitting is the same as nearly all Japanese cars, anything from Autozone works. Water however ...... ???
/ 155d slow throttle response #30
The oil pressure threads on a Yanmar are 1/8bpt. The temperature threads are m16-1.5.
/ 155d slow throttle response #31
When I replaced mine it came with a couple fittings to choose from. One was the correct one.
I will be adding a gauge but I've had a few 2 cylinder John Deere tractors that were thermal cycle and they never got over 170 even pulling a 3 bottom plow for almost 1miles rounds.
I understand that these cooling systems hold far less coolant but they are also for less engine size.
/ 155d slow throttle response #35
New member here. Just got a sweet deal on a 155d with 280 hours on it and was a 1 owner. Runs good but the throttle response is slow. Any thoughts?
Yes, my YM165 (nearly identical) tractor did the same thing one spring. The fix was to replace the fuel filter element. It didn't look clogged or dirty, but something must have changed because when I changed the element it responded to the throttle like new again.
Pay attention to that coolant. 50% antifreeze is max for a thermosiphon system. It's all in the owner's manual.
As far as I know, there are no NPT fluid fittings on the basic Yanmar engine and dashboard gauge setup. Some people have reported that they found some tapered connections that were using the Metric tapered pipe spec, but that wasn't the case in mine. All my OEM fittings that used a tapered thread were BPT (British Pipe Thread), just as all of the straight thread bolted connections were Metric spec.
However, Yanmar sourced the loader from Canada back when we bought the YM165D new. All of the loader connections were a fine and mysterious blend of metric, US, and NPT.
luck,
rScotty
/ 155d slow throttle response #36
I think that iF the fuel had growth in it. Like mold or algae, you may not be able to see it, but that microscopic growth may be so fine that it's clogging the filter yet you can't see it like if it were a bunch of black gunk.
/ 155d slow throttle response #38
Are you eliminating the idiot light in place of the gauge then?
I kept both light & gauge. Doing so is just a few extra fittings from the hardware store.
Thinking back to the gauge installation on our YM165D, It all started when I couldn't resist that cheap triple gauge set with volts, oil, and temperature in a package with all the fittings for under twenty bucks! That was 30 years ago when twenty bucks was almost real money.
But I never did like that nylon oil pressure capillary tube that came with the set. It seemed to be a possible source of leaks. Besides, who ever heard of plastic parts on a tractor? Of course since that time the nylon capillary tube has been proven in many applications. So maybe times have changed, or maybe I just like to worry... but if and when I do it again I'll try to find an electronic pressure gauge.
an old-timer, rScotty
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
Woods RM59 Finish Mower (A62613)
Woods RM59 Finish...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
2006 Kubota L5030 (A64126)
2006 Kubota L5030...
