155d FEL guick tatch or forks
   / 155d FEL guick tatch or forks #1
chevy791979
white heath IL
155d yanmar
Looking to see if anyone has or has a source for a form of guick couple or a form of forks. I'm just wanting to pictures if they are out there. Thanks in advance
   / 155d FEL guick tatch or forks #2
Might take a look at the thread about 4 down from this one. Good bit of conversation about the good and bad.
Quick tach would be nice but with a 155d having a lower lifting capacity I'd be open to a set of pin on forks. My bucket pins come out with little effort and it would not lose me any break out force.
Honestly I would mainly get used to hold logs up while sitting and moving logs around (or scooting lol ).
   / 155d FEL guick tatch or forks #6
My use may be a little different. For rasseling downed trees in the orchard, I sometimes chain them to the bucket. I have slip-on forks but this is simpler. Here's an old photo.
36619d1113245277-so-what-tractorin-did-you-625565-img_3089r2-haullog-jpg
And a rear forks set I cobbled up from scrap on hand.
70566d1171849399-pallet-forks-rear-3-pt-p1050892r-jpg
Sweet. Thanks. I've thought about rear forks also for a ballast when moving firewood with the loader. I have the OEM ballast box but if I could use wood as the same purpose it would cut my trips to the wood shed down.
   / 155d FEL guick tatch or forks #8
What I did for forks for the YM165 - same loader as the 155 - was to go to the scrap bin where I found some angle iron and a couple of four foot pieces of heavy wall steel pipe. I welded the angle iron into the sides of the bucket as you see in the photo. Now when I need forks I just slide the pipe into the brackets welded into the bucket. Plenty strong enough for anything that small loader can lift.
rScotty
rScotty
Perfect
What kind weight have you lifted you think?
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
2014 MACK PINNACLE (A52472)
2014 MACK PINNACLE...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
378764 (A51573)
378764 (A51573)
378648 (A51573)
378648 (A51573)
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
