1541 w/18hp shuts off after about 15 min.
   / 1541 w/18hp shuts off after about 15 min. #1
fuzzy
shuts off after about 15 min. but starts fine the next day. <font color="red"> </font>
   / 1541 w/18hp shuts off after about 15 min. #2
Replace coil(s).
   / 1541 w/18hp shuts off after about 15 min. #3
also check your harness running from the pto clutch, mine was shorting out and causing the same problem
   / 1541 w/18hp shuts off after about 15 min. #5
I agree with mojo. Fairly common 'issue' across the board with CC's. Check that PTO wiring! Pull back the protective sleeve on the PTO wiring as well to check for rubbing/breaks. You could also have a fuel pump issue (check for fuel in the filter after she quits), or you could have a plugged fuel cap vent. Loosen the gas cap after she quits & listen for a 'whoosh'. Like the other gents said, could be a coil heating up, expanding with an internal break.
G/luck
Joel
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53485)
THIS WILL BE A...
Pull-Behind Reel Mower Tractor Attachment (A55851)
Pull-Behind Reel...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2014 Chevrolet Cruze Sedan (A53424)
2014 Chevrolet...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
