1541 w/18hp shuts off after about 15 min.
   / 1541 w/18hp shuts off after about 15 min. #1
fuzzy
shuts off after about 15 min. but starts fine the next day. <font color="red"> </font>
   / 1541 w/18hp shuts off after about 15 min. #2
Replace coil(s).
   / 1541 w/18hp shuts off after about 15 min. #3
also check your harness running from the pto clutch, mine was shorting out and causing the same problem
   / 1541 w/18hp shuts off after about 15 min. #5
I agree with mojo. Fairly common 'issue' across the board with CC's. Check that PTO wiring! Pull back the protective sleeve on the PTO wiring as well to check for rubbing/breaks. You could also have a fuel pump issue (check for fuel in the filter after she quits), or you could have a plugged fuel cap vent. Loosen the gas cap after she quits & listen for a 'whoosh'. Like the other gents said, could be a coil heating up, expanding with an internal break.
G/luck
Joel
New Powersmart 4400 Watt Portable Generator (A54865)
New Powersmart...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Manac Walking Floor Trailer (A50322)
Manac Walking...
1990 TRAILMASTER CRUDE TRAILER (A55745)
1990 TRAILMASTER...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
