1540
RyanL
Caldwell, Ohio
MF 1540 4wd,loader, R-4s
Hi, i am getting ready to buy a 1540 4wd hydro it will have 10-16.5 front and 17.5l -24 rear R-4s, foldable ROPS, grille guard,joystick valve, 1525 loader, skid steer quick tach, 66" H.D. bucket. The price i got for all this was $22,600.
Then I priced a Bush Hog 750 backhoe, 3-point mount, power beyond, 12" H.D. bucket $5,375.
This tractor will be replacing a ford 1320 4wd loader. I will need it to mow, do chores around farm and mow,rake, bale 5 acres of hay half flat ground half moderate hill.
My question is will the hydro hold up to baling with MF 12 baler, or should i go with 12x12 trans.
The tractor i am using now is neighbors Farmall H, and my big Case 800 gas hog to do the hay but i just want the 1 tractor to do everything. (running out of sheds to store all of them)
Thanks
RyanL
I wouldn't want the hydro for use on the baler. I'm not even sure that I would use a baler for this size of tractor. Compact tractors of any brand are not made as heavy in the transmission and pto as utility tractors are.
That is a good price for backhoe, but I would be afraid of a three point mount. A subframe is a lot safer.
/ 1540
I have run the baler behind the ford 1320 but it don't have enough HP, the thing i found funny is the baler didn't rock the 1320 back and forth as bad as it does the the Farmall or Case.
I also thought about the tranny.
I would recommend you going with the 12x12, much better for that type of work. I would also think about stepping up to the 1547, if not to a 400 series machine like the 461 4wd. Good luck and keep us posted.
/ 1540 #5
I would check with your dealer before buying a 3pt hitch backhoe for the 1500 series. I believe I saw in their sales book that a 3 pt backhoe would void the warranty
/ 1540
Well, I decieded i don't have the funding right now for a backhoe so i'm in the process of getting just the tractor and loader with a few other options.
RyanL
As a price comparison, I'm looking at a 1540 w/ 8x8 tranny and r4's for $17,790, 1525 loader for $3,546, a MF Backhoe w/ 16" bucket for $6,189 and a MF Post hole digger w/ 9" auger for $825.
Don't install a 3 point mounted backhoe on any brand compact tractor while its still under warranty. I believe almost every large mfg (MF, Kubota, Deere, NH) will void the warranty if the failure can be attributed to the 3 pt backhoe. Most good backhoe mfg's will offer a full subframe for the major compact tractor brands. /forums/images/graemlins/shocked.gif
/ 1540
I got the tractor without the backhoe. It is a beast. Will post pics soon. What i got is a 1540 4wd, 10-16.5 front R-4's and 17.5L -24 Rear R-4's loaded. 1525 loader, skid -steer quick tach, 66" H.D. bucket, 48" MDS pallet forks, Tractor -mounted joystick, and used new holland 451 sickle bar mower.
Which tranny did you go with? How much?
/ 1540
I went with 12 x 12 power-shuttle, And i paid 24,900 for everything.
RyanL
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2008 Chrysler Sebring Convertible (A62679)
2008 Chrysler...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
