1540 massey heating problem
   / 1540 massey heating problem #1
bobotuff
1540 massey
got hot while brush hoging , cleaned screen and radiator . next morning temp gauge was cool ran it for 5 mins and gauge pegged hot shut off ,replaced thermostat and temp sensor, gauge still insantly goes to hot before water even warms up not sure whats going on gauge goes down with key off but second you turn key on it jumps right up and stays there when started, any help would be greatly appreciated
   / 1540 massey heating problem #2
May sound simplistic, but is the coolant level good?
Maybe there’s a grounding issue that’s causing bad gauge readings - look at all the wiring and grounds.
   / 1540 massey heating problem #3
don't have an air bubble locking system do you? sensor can read hot if air locked there.
may need to let it run until thermostat opens, that will take care of air bubbles. can tell when it opens as hose to t-stat will get hot when it opens.
   / 1540 massey heating problem #4
Your are better off turning it over to a professional before destroying the engine,if it isn't already too late. The moment ANY diesel engine overheats is time to shut it down and find the reason. "Finding reason" doesn't include tinkering then restarting to see what happens.
   / 1540 massey heating problem #5
Did you fix that issue? Was it difficult?
I have a similar heating problem at the moment and have no idea how to deal with it.
Does it make sense to sign a hvac contract, like this one maybe https://lawrina.cоm/templates/hvac-contract/ with one company or should i just find a man for a this job and next time look for someone else. Appreciate your advices.
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
3 pt Finishing Mower (A50514)
3 pt Finishing...
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
TRUCKING INFO (A50774)
