1540 + 72in. cutter
/ 1540 + 72in. cutter #1
the6shooter
oklahoma
MF 1643
does anyone have a 1540, that will pull a 72" brush cutter ? just wandering if it can. and how it does. just thinking about the next upgrade
thanks
david
/ 1540 + 72in. cutter #2
An Massey Ferguson 1540 will have no problem powering a 72" Rotary Mower.
Keep in mind that not all mowers are created equal.
When you are mowing, the gearbox is a big part of the scenario.
Less expensive mowers have lighter-duty gearboxes, while better mowers have heavier-duty gearboxes.
I would recommend the Woods brand rotary mower, Model BB72 or BB72X.
/ 1540 + 72in. cutter #3
I have a MF1428 and a 72 inch Woods rotary mower. Works beautifully. Power has never been a real issue. Occasionally going up hill in thick wet grass I have to switch to low range instead of the middle range on the hyrdostatic transmission but so what...I still get done faster than if I had a 60 inch deck. I cleared an upper lot of 1.5 inch trees with no problem. The Woods unit is solid. My only issues are related to having a big mower on a category 1 hitch. If I were to do it again I would start with a hydraulic toplink. I plan to add one this winter.
/ 1540 + 72in. cutter #4
Shouldn't be a problem... I am using a 72" on my 1533. It is better to go bigger then smaller, you can also do a smaller cut with a bigger hog, but you can't do a bigger cut with a smaller hug.
/ 1540 + 72in. cutter #5
i have a 1540 and use a 72 in bushog squeeler works great ...bruce
/ 1540 + 72in. cutter #6
I bought a 5' cutter when I bought my MF1250. The 1250 has the same engine as a 1433 and 1533. It was sized perfectly. I am still using it but it would defiantly be better to have a 6' with your 40HP. When I find a good deal on a used 6' cutter, I will have it.
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
John Deere 544C Wheel Loader (A65579)
John Deere 544C...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
360 Y-Drops (A65640)
