1540 + 72in. cutter
/ 1540 + 72in. cutter #1
the6shooter
oklahoma
MF 1643
does anyone have a 1540, that will pull a 72" brush cutter ? just wandering if it can. and how it does. just thinking about the next upgrade
thanks
david
/ 1540 + 72in. cutter #2
An Massey Ferguson 1540 will have no problem powering a 72" Rotary Mower.
Keep in mind that not all mowers are created equal.
When you are mowing, the gearbox is a big part of the scenario.
Less expensive mowers have lighter-duty gearboxes, while better mowers have heavier-duty gearboxes.
I would recommend the Woods brand rotary mower, Model BB72 or BB72X.
/ 1540 + 72in. cutter #3
I have a MF1428 and a 72 inch Woods rotary mower. Works beautifully. Power has never been a real issue. Occasionally going up hill in thick wet grass I have to switch to low range instead of the middle range on the hyrdostatic transmission but so what...I still get done faster than if I had a 60 inch deck. I cleared an upper lot of 1.5 inch trees with no problem. The Woods unit is solid. My only issues are related to having a big mower on a category 1 hitch. If I were to do it again I would start with a hydraulic toplink. I plan to add one this winter.
/ 1540 + 72in. cutter #4
Shouldn't be a problem... I am using a 72" on my 1533. It is better to go bigger then smaller, you can also do a smaller cut with a bigger hog, but you can't do a bigger cut with a smaller hug.
/ 1540 + 72in. cutter #5
i have a 1540 and use a 72 in bushog squeeler works great ...bruce
/ 1540 + 72in. cutter #6
I bought a 5' cutter when I bought my MF1250. The 1250 has the same engine as a 1433 and 1533. It was sized perfectly. I am still using it but it would defiantly be better to have a 6' with your 40HP. When I find a good deal on a used 6' cutter, I will have it.
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
Atspower Mini Excavator (A60352)
Atspower Mini...
New 4-Wheeler Tires (A65640)
New 4-Wheeler...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
