1533h gauge cluster warning light problems
   / 1533h gauge cluster warning light problems #1
kjnwi
farm pro 2425
Hello-
100 hours on tractor. Water in fuel light, air filter light are on and fuel gauge flashes on and off while showing full. Temp gauge does not appear to be working either.
Tractor runs great otherwise
any suggestions? Should I order a new cluster?
   / 1533h gauge cluster warning light problems #2
Did you ever get a resolution?
It likely needs an ECU update. I had the same problem on a 1538.
   / 1533h gauge cluster warning light problems #3
I also am curious about a resolution. It sure would be helpful if an OP would just write a few lines after the problem was resolved. I also developed a couple problems with the cluster. Since around 200 hours the MIL light has been flashing with no apparent problems in the tractor. The temp gauge has never worked properly and at 1-2 bars the tractor is at operating temperature as verified with testing. Although I have heard about the ECU flash, the dealer I spoke to was not aware of this service. At somewhere around 300 hours, the cluster failed and lost all digital function, fuel and temp gauges and tach. After verifying power and ground connections, I replaced the cluster and problem was fixed, but not the flashing MIL. I will mention that the dealer who sold the tractor is no longer a dealer and the nearest dealer is a considerable distance away, so I will live with the flashing light and wonky temp gauge until, hopefully, we are granted right to repair and fix this myself.
FORD 7600 TRACTOR (A51243)
FORD 7600 TRACTOR...
NAMCO GRAIN-O-VATOR GRAIN WAGON (A51243)
NAMCO...
2011 FORD F-250 SUPER DUTY FLATBED TRUCK (A51243)
2011 FORD F-250...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2015 Ford F-150...
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
