1533 Implements
   / 1533 Implements #11
I thought the 5' would be the best as well. However, the dealer suggested a 6' cutter, saying that the tractor can more than handle it in light cutting and that with R4 tires, a 5' mower won't even cover the tractor width. More thoughts?
Nasty,
He indicated earllier that with the R4's the 5' was narrower than the tractor. This would be a problem for me trying to cut next to fencerows, etc., as well as being able to cut a 6' width vs 5'. I believe in the first post he said he would be clipping pasture for livestock? A light front end will be more problem than power to run the cutter. /forums/images/graemlins/smile.gif
   / 1533 Implements
Yeah, it's a very tough problem. The tractor is 62" plus whatever added width of the industrial tires. I think the 5' mower would be the better all purpose mower but the added width of the 6' and the ability to cover my tracks and get next to fences is a real plus. The tractor has a FEL so the front end weight is there if necessary. My use is on pasture, so I shouldn't be mowing any tall hay, brush, or saplings. That said, I could always contradict myself and say it'd be nice to have the option, however.
   / 1533 Implements #13
Here is my thoughts… I have a 1533 with a 72” mower and it has no problem cutting my pasture grass here in Florida at low range 4th gear (high range, 1st gear tops). I have done some brush cutting with it and no problem there as well. I to wanted the bigger mower because of my fencing, but guess what? Get the “I need a 72” mower to get close to my fence”, out of the reasons to get a 72” mower, it still will NOT cut next to your fence, trust me on that. The mower is only about 5” wider (I think even less) on both sides of the tractor, it seems to be allot to get up to a fence rail, but it isn’t, you still can’t get up to the fence… In any case, go for the bigger mower for the reason of making less passes and not for getting next to something. It has been side here all over the place, you can make a bigger mower smaller, but you can’t make a small mower bigger.
72" weight... Not a problem. I have cut grass without the loader and no problems. Yes, I have had the mower all the way up on the 3point with no front end lift.
Last thought on the mower… If the 1533 that we are talking about is a hydro, forget about the 72” mower and go with the 60’, the hydro doesn’t have the HP to turn a 72” IMO.
About the 1433v and 1533 width… I am not sure what one is wider or not, but the 1533 comes with the adjustable wheels (remove from hub and make them wider)… Isn’t the 1433v wheels a solid wheel? If that is the case I think the rear track would be wider on the 1533 then the 1433v right from the start because of the wheels the 1533 comes with.
EDIT... Forgot to say I have the R-4s... Also here is the best pics I have right now with the mower on, again it looks as if you can get next to fenceing, I still have to use my riding mower. Remember the blade sits back a bit from the side of the mower.
(note the grass the tractor is sitting on in this pic is done by a riding mower not the brush cutter)
   / 1533 Implements #14
I measured my 1433v today to decide what size Bush Hog to get. I have R4's and I measured 60 1/2 inches outside to outside on the rear tires. I will get a 5ft because I plan on doing some heavy cutting.
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
Toro Z Master Mower (A50324)
Toro Z Master...
2020 Barreto 20RTK 36in Stand-On Trencher (A49461)
2020 Barreto 20RTK...
2012 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2012 MAXEY TRAILER...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
Informational Lot - Shipping (A51039)
Informational Lot...
