1530 John deere steering
   / 1530 John deere steering #1
sgoerdt
1530 John Deere
The power steering on my 1530 works but when I turn to the right it has some hesitation almost as thought it is pulsing or have to overcome pressure and then has a whine sound. No hesitation or sound when turning to the left. No hydraulic leaks everything else works as it should. Any help on diagnosing the problem would be greatly appreciated.
   / 1530 John deere steering #2
My guess is one or more of the 6 large o-rings inside valve housing has failed or the RH control valve has failed. Due to the cost of the individual control valve(AR81610 @ $1382 each) I'll recommend to 1st R&R of the 6 o-rings. These 6 o-rings can be replaced by removing steering wheel & large adjusting nut, then turn shaft CCW to remove shaft assembly with valves, shims intact. Don't disassemble valves & shims without documenting location of each shim.
New Wolverine Push Blade (A53002)
New Wolverine Push...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
1272 (A50490)
1272 (A50490)
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
