1528 massey ferguson
/ 1528 massey ferguson #1
superdave24
I need help i have a 1528 massey and my hydraulics seem to whine and pulse when cold and are weak when warm I don't know what to do next I have replaced hoses but wondering if I need to rebuild the cylinders or if I can tell if I need to do that or change the pressure relief valve ? Thanks in advance for any and all help
/ 1528 massey ferguson #2
Hello Dave. I have witnessed air in hydraulic systems cause jerkiness and I’m sure it could cause weakness also. I don’t think the cylinders are the fault of this. And the way I would purge it at this point would be the use them. Then if it isn’t operating correctly, continue posting
I have tried to continue operating for a while now and dosent seem to change the result hense the reason I thought maybe I have a bad cylinder. I do need to change the hydraulic filter but I'm not sire if there is only one filter or 2. I can't seem to find any literature on how to or instructions..
Thank you for your advice and help.
/ 1528 massey ferguson #4
If you're hoping for any meaningful help, you might start by identifying which transmission you have. The hydraulics between the two will be similar in some respects but certainly different in others.
/ 1528 massey ferguson #5
Hi @superdave24 - I operate a 1533 built in 2005. It is an 8x8 SynchroShuttle tranny. Having just serviced our hydraulics and I know that the 1528 is a different platform, the pulsing mushy nature could very well be entrapped air. There is a bleed procedure that has to be done if a line is opened. The entrapped air takes quite a while to bleed out. There should be a procedure for bleeding in the Operator's manual. If you don't have an operator's manual, they are available from AGCO.
I think you will get more answers if you post your thread in the Massy Fergusuon sub-section here.
