1527 diesel won't stay running
   / 1527 diesel won't stay running
Just looked and there is nothing blocking the line or pinching it.
Update
I hooked up my air comperssor to the return line and could not get any bubbles in the tank and that was with 80 lbs of air.
I then hooked up a clear hose to the return line and placed the other end into a pop can, and sure enough I had a lot of fuel flowing and the thing ran great. So now I need to tear the tank out and see what is up with the return line.
Thanks for you help.
I GOT IT !!!!!!!!!!!!!
At least I think :)
Summary....
I blew air down the fuel return line with the fuel cap off the tank, and guess what no bubbles. I then disconnected the return line and ran a clear line into a pop can and it fired right up and ran great. In the process of removing the tank I closed the fuel petcock (in the direction I though was closed) and then all the sudden a ton of fuel started pouring out my return line. The feed and return lines must have been switched around at sometime. I hooked everything back up and it runs fine now.
Now I did check the feed line for fuel flow with the petcock in the closed position and it feed great now I know why. Now I know which way is open and closed on the petcock and which line it is hooked up to. From what I have heard this is common thing to do on these Cub diesel because there is a screen on the petcock that can plug, so people reverse the feed and return lines so that the feed line does not get plugged.
Thanks everyone for your help, and I hope I don't have to post a new post with this issue again.
   / 1527 diesel won't stay running #24
Glad you got it fixed. I just saw your U-tube video and was for sure it was a fuel related problem. Those little Kubota diesels will take a lot of abuse and run many hours. I always ran mine wide open.
kj
2011 Liebherr L586 Wheel Loader (A55218)
2011 Liebherr L586...
2021 Ford F150XL (A53314)
2021 Ford F150XL...
2009 Chevrolet Cobalt Sedan (A55758)
2009 Chevrolet...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2015 Ford F-750 Stellar 10628 Mechanics Crane Truck (A55852)
2015 Ford F-750...
2006 International 7500 Asphalt Distributor Truck, VIN # 1HTWNAZTX6J383773 (A54865)
2006 International...
