1520 Cracked rear axle
   / 1520 Cracked rear axle #1
mwh
'90 Ford / New Holland 1520
Hi all. My dad has a '90 Ford 1520 (1st hand owner) with HST and FEL. I don't know the hours by memory, but I know that it has relatively low hours for it's age.
While coming back from splitting some wood at the neigbhour's place late in the evening he forgot to drop down to medium from high gear before climbing the steep hill leading to his place. My dad tends to run the machine at lower RPMs when moving from one place to another and the engine started to lug down while on the hill. The splitter he has is pretty hefty and was attached to the 3-point. He tried giving more throttle, but to no avail and the tractor started to roll backwards down the hill. The brakes did not help in stopping or slowing the tractor and he ended up hitting a tree with the splitter and finally, the right rear wheel.
At that point, he was able to switch gears and move forward. After parking it, he noticed a crack in the right rear axle housing and low Hydraulic fluid. The low fluid is not uncommon after splitting since the piston on the splitter tends to leak quite a bit under use so I'm not sure if it's related to the crack.
The thing is that there was rust along the crack which could mean that it was already there (at least in the form of a fissure) and when the dealer came to pick it up for repair, the fellow said that he's seen cracked axles before and that somethign like dropping a full FEL bucket on a hard surface can cause it.
Does that last statement make sense? Have any of you seen cracked rear axles on this series before?
My other question is about the brakes: Is it normal that they did not help in stopping or slowing the tractor? I realize that they are oil brakes, but still seems like they should have helped a little here.
Thanks for your feedback.
   / 1520 Cracked rear axle #2
All things will break,so,,that sounds normal enough,,brakes,some tractor brakes work better than others,but that sounds normal too,,,stuff happens to all of us that own machinery:)
   / 1520 Cracked rear axle #3
I discovered that the brakes on my TC29D are field brakes, and not road brakes. When going down a moderate slope I couldn't stop but fortunately didn't have to, I just wanted to in order to turn. I was in high range, and now I know better. I knew if I had to stop, I could, but perhaps at great cost in terms of damage.
   / 1520 Cracked rear axle #4
Broken rear axle housings are not at all common.
But under the circumstances, I'm not surprised that your Dad has one.
   / 1520 Cracked rear axle #5
I've seen one housing bend after a similar accident. Never broken due to dropping a loader.
1999 Starcraft Starlite 25RTB 25FT T/A Travel Trailer (A51694)
1999 Starcraft...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
2015 Ford F-350 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
