1520 and T110 FEL lift capacity.
   / 1520 and T110 FEL lift capacity. #1
tractordog
Southern New Hampshire
T1520
Hi,
The manual for my T110 FEL has a lift capacity listed for the 1520 at 770 pounds.
Is that realistic? With a quick at at the end and pallet forks do you think 500 might be more like it.
I may be picking up a five hundred pound load out of my pick up and was not sure.
TD.
   / 1520 and T110 FEL lift capacity. #2
I have that loader on my T1510
I think the lift capacity is very light ....and less than what they say.
You can feel the loader strain with 3/4 or full bucket of dry dirt. Snow...it will handle, but dirt not so much.
Although...I easily lifted a Landpride RTA 1266 in the crate off my trailer with it...no strain at all. The Landpride site says the tiller weighs 448 lbs.
   / 1520 and T110 FEL lift capacity. #3
also...you say you have a quick attach on your tl110?
I thought they were not available without making your own.
May I ask where you got yours from?
I got it from the dealer this year. Did not know it was anything new for the 110. The plate on the 110 says it was built in 2009.
   / 1520 and T110 FEL lift capacity. #5
thanks...I will have to see my dealer about one
   / 1520 and T110 FEL lift capacity. #6
Just an after thought here, but are you possibly mistaking the "quick mount" loader assy for a quick attach bucket? There is a big difference.
The quick mount loader allows for the whole loader assy to be removed / installed in short time, but the bucket itself is pinned on and not a quick attach type.
The NH site does not show any quick attach options available.
http://agriculture.newholland.com/u...Compact-Tractors/Pages/products_overview.aspx
Do you have the quick attach and forks on it now?
If you do have a quick attach plate and forks, could I get you to snap a photo of it?
I have never had the loader off,
Swap the bucket and pallet forks many times.
Will take picture when able. Too bad manuals are not online I could just point you to the page with the quick disconnect.
TD
   / 1520 and T110 FEL lift capacity. #8
Thanks...I guess there is no need for a photo seeing as you have it and you got it from a NH dealer
I will just ask my NH dealer about it
Thanks again
   / 1520 and T110 FEL lift capacity. #9
I have a T1510 with the 110FEL. I used to move around my gas powered welder at 500 lbs, with rear back blade as ballast, with no problems at all. I too have the quick attach bucket, and I like it.
John Deere 333E (A47477)
John Deere 333E...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2002 Mack CX613 Cab & Chassis (A53117)
2002 Mack CX613...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2000 Honda Foreman 450 ATV (A53117)
2000 Honda Foreman...
