1510D repairs
   / 1510D repairs #1
srscott
South West Louisiana
YM1510D w/ FEL
Hello all, it's been awhile since I posted anything here. I've been pretty tied up for quite awhile. Seems like when problems come they don't like coming alone!
Anyway, I have two questions about repairs to the 1510D. It's got 208 hours on it and has not given me any problems other than I'm going to need to replace the seals on the front drive knuckles. I got the owners manual for the 186D, which is supposed to be the spitting image, but the knuckles shown in the manual look to be a different design externally than whats on my tractor. Has anyone replaced the seals on the knuckles?
2nd problem not addressed in the manual is the shifter to engage the 4wd. I was out moving the driveway gravel from point A to point B, and just generally making a mess of it today and had the 4wd engaged. It engaged fine with no excessive pressure. When I went to take it out of 4wd at the end of play time the shift lever just flopped back and forth.
I didn't get a chance to look at it closely before it got dark but I suspect it may be a shear pin. However if that isn't the problem and I need to check the shift fork will I have to split the tractor?
   / 1510D repairs #2
   / 1510D repairs
Thanks for the quick reply Aaron.
If Part #6 needs to be replaced do I have to split the tractor to get to it?
   / 1510D repairs #4
Nope. It can all be removed from the outside. Just remove 7, 1, 3,5, 6 and put the new one back in. Be sure to clean & lube the #22 from the bottom because that is usually what causes the binding & makes the part break in the first place.
Aaron
Parts@HoyeTractor.com
(940)592-0181
2019 Hustler Super Z 60in Zero Turn Commercial Mower (A51691)
2019 Hustler Super...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
J and L Cargo Express Shadowmaster Enclosed Trailer (A53473)
J and L Cargo...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2020 Can-Am Ryker Rally 900 Ace 3-Wheeled Motorcycle (A51694)
2020 Can-Am Ryker...
