1510D 4WD lever just flops!
   / 1510D 4WD lever just flops! #1
rooskyrider
central florida
Yanmar 1510D
I was in 4WD while doing some sand loading, and 4wd quit. Lever just flops? Where do I begin? I've had it a month and a half - bought it "refurbished" from greymarket dealer. No warantee. /forums/images/graemlins/mad.gif
   / 1510D 4WD lever just flops! #2
rooskyrider:
Will your dealer stand behind it, if so take it back to him. If not your not dealing with a big problem it's most likely a bent fork of broken spring just inside the tranny housing. I don't have my books close buy but there ain't much to the lever that's floppin' around on you but, the tractor will have to be busted in half to fix it.
Opps....just reread your post...no warantee, ever bust a tractor in half?
   / 1510D 4WD lever just flops! #4
I replaced the detent ball and spring on my 186D 4WD shifter without splitting the tractor. The 1510D should be very similar as it is almost the spitting image of the 186D. The detent is a little ball that holds the lever in place, just like the detent on the square drive of a ratchet holds a socket. By your description of flopping around, it sounds as if you may have a similar problem or a sheared pin where the lever connects to the engagement shaft (easy to fix-replace roll pin). Does the 4WD work when you hold the lever in the forward position?
Jeff
   / 1510D 4WD lever just flops! #5
rooskyrider:
Looks like I may have give you bad info, my bad I thought all the parts were in the inside and only the lever stuck out of the tranny....opps
   / 1510D 4WD lever just flops! #6
I fixed mine on a 226D. I had to drain the trans to pull the gear box off but it was a eazy fix. I hear some you just slide the parts out. If I can do it anyone can.
Jim
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
78in Screening Bucket Skid Steer Attachment (A51691)
78in Screening...
2007 Anderson 25ft T/A Flatbed Equipment Trailer (A51692)
2007 Anderson 25ft...
2025 AGT SDA-140T (A50123)
2025 AGT SDA-140T...
