1510 Starter problems
   / 1510 Starter problems #1
LD48750
Veteran Member
SE, MI
Ford 1510 Mahindra 1526
Starter switch has been acting up for the last couple years.
Previous owner installed a starter button and that has been working fine UNTIL yesterday.
Jumped it with a screwdriver once & everything was working good again.
Today nothing.
Battery good jumping with screwdriver gets nothing, not even a click.
Trying to take starter off to run up to repair shop & can't get it out.
Part of the hydraulic system is in the way.
Is there a trick to getting the starter out or do I have to break open the hydraulics?
Here is some pics for your big brother 1710 that might help. Starter removal Ford 1710 - Yesterday's Tractors
Yup... That looks like it.
But just like that poster, I cleaned everything up & put it all back together (without getting it out of the tractor) and IT WORKED!
Well.... twice anyway. Then back to the screwdriver.
Going to order an ignition switch & see if that helps.
Most of what I find says this tractor is self priming so if I do have to get into the hydraulics it shouldn't be bad.
Well... I have ordered a new starter key switch.
Will try using a jumper cable and see if that indicates a bad cable.
Today was hit & miss, switch worked part of the day then quit.
Screwdriver to the rescue.
   / 1510 Starter problems #6
Check all connections including the ground to the frame. I had some issues on my 1920 and the ground to the frame was rusty, cleaned it up and no more issues.
2001 Ford F-350 4x4 10ft Flatbed Truck (A55852)
2001 Ford F-350...
8ft Fork Extensions (A55851)
8ft Fork...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
Kubota LA1055 (A53314)
