1500d pops out of low gear
   / 1500d pops out of low gear #1
pingdaddy37
i 'm plowing my back yard, then it started coming out of the low-low gear.can you all help? this is the first time that this has hapened. this is the first time that i have used a plow on my tractor. :confused: :confused:
   / 1500d pops out of low gear #2
The plow is nost likely not the problem. If you can pull it in another gear do so and then fix the problem later. Could be wearo or miss adjustment on the shift linkage. If the gear is not fully engaged it will pop out of gear. I hat that to happen on my 2020 once and it turned out that I did not fully engage the shift leaver. Has not happened again.
   / 1500d pops out of low gear #3
I have noticed that my 1500D would do the same when I was pulling under a very heavy load. ie using the rake or box scraper and going up a steep incline in 4wd. The high/low will pop out into neutral. Maybe not a bad thing, so something does not break. Not a common issue, but would like to hear other comments on the subject incase something needs to be looked at....
VT
   / 1500d pops out of low gear #4
It won't get better. could be bent fork , but probably warn gears.
   / 1500d pops out of low gear #5
VT
It definitely needs to be looked at. Could also be a binding spring loaded detent, (ball).
   / 1500d pops out of low gear #6
Thanks Len and Norm,
Is there a relatively easy way of checking on these items or do I have to do a major disassembly?
   / 1500d pops out of low gear #7
I would start at the end of the shift lever and see where it leads me.
thanks for your help,:) i put my foot on the shift lever to hold it in place.:cool: i'v put the plow away till the end of the year. one thing was that the gound had never been plow befor,but something must be wrong. i will check it after my garden work is done.:)
   / 1500d pops out of low gear #9
Personally, to keep my foot free, I would try to use a bungee cord to strap the lever down to hold it in place until you can fix the problem.
Travis R
   / 1500d pops out of low gear #10
I happen to have an extra 1500-D tranny on a pallet if push comes to shove,, to bungy ect....
Ernie
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2015 Ford F250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F250...
2019 Nissan Sentra (A51694)
2019 Nissan Sentra...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
