Oil & Fuel 1500D Fuel shut-off lever
   / 1500D Fuel shut-off lever #1
Onthesauk
NW Washington
Ford 3000
Any suggestions on how to get the fuel shut-off lever, (at the filter,) to turn? If I put any more pressure on it I'm sure I'll either break it or strip something.
   / 1500D Fuel shut-off lever #2
Mine is the same way. I just use vise grips and squeeze the line shut before the filter assembly. Be careful, if the line is old and brittle, you may damage it and end up with a good spill plus the need to replace the line from the tank to the filter. If you have to do that, you can put a workable shutoff valve in the new line.
Thanks Mike, think you're probably right.
   / 1500D Fuel shut-off lever #5
I just sent the link to Hoye, but there are lots of dealers here that probably could get that assembly for about the same price. Let's see Washington State, EFC is out there, but an item like that could easily be mailed, there also LMTC in Ohio, and others inbetween--sorry if I have not mentioned your name and you deserve mentioning. :D
Mike
   / 1500D Fuel shut-off lever #6
Mine was the same way also. I finally tried turning it in the opposite direction, it moved just a fraction and found that it wasn't fully open. It then easily turned in the shut off position.
Give it a try if you haven't already.
I've got just a hair of play in it but simply refuses to go any further. Suppose I could simple force it and if it strips or breaks I can order a new one. No worse off then the way it is.
   / 1500D Fuel shut-off lever #8
Have you tried a lube on it, like WD 40 ? I had to lube mine last year
I've been dripping Rust Reaper in there, (which will usually loosen anything up,) all Winter long.
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2008 Ford F-450 Service Truck (A53422)
2008 Ford F-450...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2014 Chevrolet Cruze Sedan (A53424)
2014 Chevrolet...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
