1500d driveshaft question
   / 1500d driveshaft question #1
cam0148
Penticton, BC Canada
Cub Cadet EX3200
Has anyone ever made or had made a universal joint style drive shaft for a 1500d.
I am having nothing but issues with my, keeps loosing the 4wd, because the steel balls keep falling out of place.
Therefor I was thinking that a ujoint might be a better solution.
Thanks,
Jeff
   / 1500d driveshaft question #2
I've never done it, but it sure seems like it should work. My YM1110D and YM1301D both use universal joints on the front drive shaft. So does the YM1510D.
I dont suppose you could take a pic of the u joint to show me.
It would be helpfull to show a machinest what I really want done.
Thanks,
Jeff
   / 1500d driveshaft question #4
If you do put in universal joints , you'll also have to allow for a change in length. Before you go to all the work to do this you may want to replace the spring. I've come across a couple YM1500ds with this problem & the spring was not strong enough.
Thanks for the advice on the spring. I have already replaced it and the spring did not help.
When I look at the pinion in the front axel one of the groves is worn more then the others, which I beleive is the cause of the slippage.
Ex Mark Zero Turn (A51573)
Ex Mark Zero Turn...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A52577)
2002 WESTERN STAR...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
