15" Wheels for my 825i Gator
   / 15" Wheels for my 825i Gator #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
Does anyone have 15" wheels on their Gator, especially the 825i model. I'm looking to buy more of a radial street tire for my Gator, and I've read that a 15" wheel would fit. If you have a 15" wheel on your Gator, what radial street tire do you have on your 15" wheels? Appreciate any information . . . looking for specific information on a correct wheel/tire setup.
Thanks,
FredSG
   / 15" Wheels for my 825i Gator #2
Don't own a Gator, but a 235/75-15 tire is nominally 28.9" OD. If you find that people are running 28 or 30 inch tires on their Gators then street tires of that size would fit. I came very close to putting them on my Defender and kind of wish now that I had. It would have handled a lot better on the road with them. (not as much sidewall flex)
Hi Tennsawdust,
I'm looking at a 225/75/15 or better yet a 205/75/15 radial tire for the 15" wheels (6" width) . . . which would give me a 27" diameter. I was hoping that someone had gone this route with their Gator, and was wanting to pick their brain for choices that I could make.
Thanks for your reply.
FredSG
   / 15" Wheels for my 825i Gator #4
Personally, I would be looking for a bias ply tire rather than a radial. Bias ply is better suited to being "aired down" to low pressures often used on ATVs/UTVs. If you are going to be running something closer to normal street tire pressures, then this probably won't matter much.
   / 15" Wheels for my 825i Gator #5
For a good combination of on and off-road performance, you might try the Super Swamper TSL-Bias in a 29x8.5/15 size. They are legal for on-road use on light trucks, but have excellent grip for off-road use. They are designed for a 6" wide rim. THe Bias ply tire takes well to being aired down for off-road use.
I have a very similar tire on my antique Coot (amphibious UTV): The Super Swamper TSL/SX bias ply in a 29x10.5/15. They are very similar to the ones mentioned above, but wider. (I'd have liked to go narrower, but my rims are 8 or 8.5" wide, and these were the ones that fit those rims.)
   / 15" Wheels for my 825i Gator #6
I have DOT summer radials tires for my RZR mounted on 12" rims. I run them at 10psi otherwise the ride transmits too much vibration. I don't really have a good photo to share but just to sayt that DOT tires exist for your Gater without going to larger wheels.
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
US 100 hp Electric Centrifugal Pump (A50121)
US 100 hp Electric...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
NEW Wolverine Skid Steer Vibratory Roller (A53002)
