15 series New design or Old design?
   / 15 series New design or Old design? #1
Grand_Pooba
Wyoming County, NY
Bobcat CT230 & John Deere X324
I just "discovered" mihindra tractors a couple weeks ago in my reseach for a new tractor so excuse me if I'm a little uninformed. Why do the 1815 and 2415 look different then the rest of the 15's. Different hood, fenders and lighter specs. Are they lighter duty?
   / 15 series New design or Old design? #2
I believe that there are (3) frames in the series starting with the 1828 on through to the 3215. There is a mix of horse power to frames so it not a smooth transition through the model numbers in relation to size. Check out the wheelbase stats. to determine frame and then note the hp For example the 2815 is the largest frame but the next highest model number is the medium size frame and has more horsepower. I've become a Mahindra fanatic as I have found the tractors to be super and the people at Mahindra to be extremely friendly and helpful.
   / 15 series New design or Old design? #3
Up until a year or so ago, the 15 series included the 2015, 2615 and 3015 (each available in gear or HST). Last year, they added four more to the mix 1815, 2415, 2815 and 3215. So, the 18, 24, 28, and 32 are a newer design. Some folks like the new design better, some not so much. I haven't really looked at the newer ones that much, so I don't know what the real differences are.
I really like my 2615 4WD (gear). The only thing I wish were different about the basic design is the location of the loader joystick. Since I got my grapple, I'm using the loader almost continuously. Having to reach for the stick constantly gets tiring. I may attempt a modification one of these days. I think I could cut the "post" that the control valve and joystick are mounted on and weld it back adding a little angle to it. That'd put the joystick in a more comfortable position, but would eliminate any chance of mounting/dismounting the tractor on that side. I always mount/dismount on the left side anyway.
I think the newer models in the 15 series relocate the joystick to the right fender, eliminating this problem.
Later,
BR
   / 15 series New design or Old design? #4
I am getting low on tractors right now and am ordering a truck load which should be in in about a week. Then I should have a good cross section in stock and I will be glad to set them side by side and go over the advantages of each with you. Give me the time to show you the product and I will answer your questions. Even call me and I will do my best. I hope to here from you.
   / 15 series New design or Old design? #5
The new design of the 15 series tractors is Mahindra's attempt to make a sexy looking tractor, IMO. On the other hand, the fuel tank was relocated from behind the seat, to under the hood. Thus, giving a larger operator area. The loaders on the newer models have tidier hydraulic hose routing, with covers.
2002 Wilson Hopper Bottom Trailer (A50514)
2002 Wilson Hopper...
2008 CATERPILLAR 573 FELLER BUNCHER (A51242)
2008 CATERPILLAR...
2006 Ford F150 (A50323)
2006 Ford F150...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
