15 Ft Rotary Cutter
   / 15 Ft Rotary Cutter #1
Hambone
Platinum Member
Southeast Kentucky
JD3032
How much horsepower would it take to run a 15 ft cutter.
Probably 10 to 15 % grade (guessing on grade %, about a 3 to 1 slope).
Been looking at a JD 5520 MFWD open cab.
   / 15 Ft Rotary Cutter #2
John Deere calls for a minimum of 55 hp pto to run both their CX15 and their HX15 flex-wing rotarty cutter. Don't know what kind of hp you would need to add for the grade, but the 5520 has lots of power to offer. I seriously considered a 5420, but decided on something a little smaller.
   / 15 Ft Rotary Cutter #3
The 5520 has I believe 72 or 75 pto hp which should be fine to run a 15' cutter. You might want some weights on the front for doing hills or if you have a loader on that would do it.
Thanks guys. Just did not want to get something a lot bigger than we needed.
This stuff is quite a bit bigger than my 2210!!!
Good idea about the weights. No loader. The loaders on ag equipment are not too good for construction applications. Visability is limited.
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56138)
2015 FREIGHTLINER...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
CATERPILLAR 430D IT BACKHOE (A52707)
CATERPILLAR 430D...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
