15 Ft Rotary Cutter
   / 15 Ft Rotary Cutter #1
Hambone
Platinum Member
Southeast Kentucky
JD3032
How much horsepower would it take to run a 15 ft cutter.
Probably 10 to 15 % grade (guessing on grade %, about a 3 to 1 slope).
Been looking at a JD 5520 MFWD open cab.
   / 15 Ft Rotary Cutter #2
John Deere calls for a minimum of 55 hp pto to run both their CX15 and their HX15 flex-wing rotarty cutter. Don't know what kind of hp you would need to add for the grade, but the 5520 has lots of power to offer. I seriously considered a 5420, but decided on something a little smaller.
   / 15 Ft Rotary Cutter #3
The 5520 has I believe 72 or 75 pto hp which should be fine to run a 15' cutter. You might want some weights on the front for doing hills or if you have a loader on that would do it.
Thanks guys. Just did not want to get something a lot bigger than we needed.
This stuff is quite a bit bigger than my 2210!!!
Good idea about the weights. No loader. The loaders on ag equipment are not too good for construction applications. Visability is limited.
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
Semi Roll-off 2 Axle Trailer (TITLE) (A50774)
Semi Roll-off 2...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
