15 degree plasma torch?
   / 15 degree plasma torch? #1
Jeepnford
NE Missouri
Case DX35
I'm still looking on the web at Hypertherm 45XP plasma cutters. I found one that comes with a 45 and a 15 degree hand torch. I've looked a little bit and haven't come up with much on uses for the 15 degree torch. Anyone with experience on what they're good for? I don't want to buy something that will sit unused.
   / 15 degree plasma torch? #2
to my knowledge 15 degree is typically used when gouging (handy for removing welds when you want to save/reuse parent material)
   / 15 degree plasma torch? #3
Or tight access/hard reach areas I understand. Seems to be a specialty tool that for most, wouldn't be used.
   / 15 degree plasma torch? #4
I usually just lay my torch on its side and make short arc burst for gouging, but If I had the 15 degree torch, I would probably find a use for it.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
2018 JOHN DEERE 8370R LOT NUMBER 266 (A53084)
2018 JOHN DEERE...
TEST BID LOT (A50775)
