15 degree plasma torch?
   / 15 degree plasma torch? #1
Jeepnford
NE Missouri
Case DX35
I'm still looking on the web at Hypertherm 45XP plasma cutters. I found one that comes with a 45 and a 15 degree hand torch. I've looked a little bit and haven't come up with much on uses for the 15 degree torch. Anyone with experience on what they're good for? I don't want to buy something that will sit unused.
   / 15 degree plasma torch? #2
to my knowledge 15 degree is typically used when gouging (handy for removing welds when you want to save/reuse parent material)
   / 15 degree plasma torch? #3
Or tight access/hard reach areas I understand. Seems to be a specialty tool that for most, wouldn't be used.
   / 15 degree plasma torch? #4
I usually just lay my torch on its side and make short arc burst for gouging, but If I had the 15 degree torch, I would probably find a use for it.
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
1995 GMC CHIPPER/BUCKET TRUCK (A52576)
1995 GMC...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
