15-40 oil for my mt160?
   / 15-40 oil for my mt160? #1
BenQ
Lancaster PA
Mitsubishi mt160d
I'm changing the oil in my mt160 for the first time since I bought it. I've looked in the manual and under the hood and did a quick search on this site. I can't find any specs on the recommended engine oil.
At work we run 15-40 in our diesels (trucks and tractors) but they are much larger than the this one.
Not wanting to hurt my engine I thought I'd better ask if anyone if 15-40 is what I should be running.
thanks in advance
BenQ
   / 15-40 oil for my mt160? #2
That should work fine. I use it in my Massey and Kioti.
   / 15-40 oil for my mt160? #3
I use Rotella 15w40 for every engine I own. Cars, trucks, tractors. Diesel and gas...................
That's what I'll do then.
Thanks
   / 15-40 oil for my mt160? #5
Shell Rotella here for all my diesels too.
   / 15-40 oil for my mt160? #6
I have used DELO 400 in both diesels and gas engines, small to large stationary engines for 50 years. It is made in a 15-40 and several others. Never had a problem and it helps keep your engine clean if you change regular. It was originally formulated for heavy duty diesels. It meets the specs for my Kubota.
Ron
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2020 Dodge Ram 5500 Auto Crane 6406H 6,440LB 3 Ton Mechanics Crane Truck (A52377)
2020 Dodge Ram...
2020 INTERNATIONAL LT625 TRI AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
