14T Baler Problems again....
/ 14T Baler Problems again.... #21
I agree the slip clutch is a likely problem. Also I would check the bushing in the flywheel. While the shear pin is not installed, grab the top of the flywheel and try to rock it in and out. If the bushing is excessively worn, it causes pins to shear also. I see you are showing a Case 830 tractor. I am not familiar with their normal operation. Is the pto able to be feathered on or does it slam on with a jerk? The heavy flywheel will shear the bolt if pto is not engaged smoothly.
/ 14T Baler Problems again.... #22
It can be eased on thanks
/ 14T Baler Problems again.... #23
Well, I got the slip clutch off but I'm not sure how to check it to see if its the problem
/ 14T Baler Problems again.... #24
Disassemble the slip clutch to investigate if any linings are stuck to pressure plates.
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
FORD F750 BUCKET TRUCK (A65054)
FORD F750 BUCKET...
211298 (A62131)
211298 (A62131)
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
Bobcat A770 (A60462)
