1470 mo-co lift cylinder
   / 1470 mo-co lift cylinder #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
Hello, I got my new to me mo-co and got it hooked up to the tractor, so far so good, I go through the hydraulics, hydraulic sway works, but the hydraulic lift doesn't, it is single acting and my tractor manual says to hook it up to the lift SCV and use float to lower attachment. I did that and nothing, I brought my rpm's up and still nothing, I check the rear and the transport guards are off, I've even tried the other lift SCV's with no luck. Anyone got any suggestions on what I could try or what I'm doing wrong?
Thanks.
Corey.
   / 1470 mo-co lift cylinder #2
My old moco had a pin with a clip in it on the other side from the lift cylinder on the back
I'm not sure what happened but suddenly it dropped down and now it's working properly, now I'm having an issue setting the float, it says to set the right from 88-154lbs and the left from 154-198lbs, I imagine its the force it takes to lift the cutting bar up? If so then what do I use to measure the force and when I lift it up I have to push it back down (sticky maybe)
UNUSED WOLVERINE PFF1-13-45W UNIVERSAL MAST (A51248)
UNUSED WOLVERINE...
(APPROX 100) UNUSED LANDHERO T-TOP BOLLARD (A51248)
(APPROX 100)...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
