1466 Turbo
/ 1466 Turbo #2
Welcome to the forum. Have you cleaned the fuel filter and air filter and is the fuel turned on. What color of exhaust. Black, blue, white, clear...
/ 1466 Turbo
Changed fuel filters recently,exhaust clear.
Did not check air filter yet. Had to come to the old job.
/ 1466 Turbo #4
I would check the air filter but I doubt that is the problem if it has clear exhaust. Pluged air intake causes black smoke. Does it shut off after a constant time?
/ 1466 Turbo
It was running great.All at once started missing.The area I was plowing was rough, that's why I thought might be rust or trash from tank.
/ 1466 Turbo #6
There might be something stuck in the injectors then. Probably need to clean them.
2016 Ford Explorer (A59231)
2016 Ford Explorer...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
2005 Ford F1-50 Ext. Cab Pickup Truck (A61573)
2005 Ford F1-50...
