1464 FEL removal....
   / 1464 FEL removal.... #1
tz666
Watson, LA
MF 1230
I have to take the FEL off to fis the water pump/fan whatever is out of wack. I got the loader off but the way I finally did it was definately not the way it is supposed to be done. I thought you could put the bucket down and pull the 2 pins and reverse out of it. I couldnt get that to work. I dont have a manual, can someone tell me how to do this the right way. From what I understand I would be able to drive in and out of it.
I removed and reinstalled my loader to fix my waterpump. I learned the ins and outs of how to do it. The first major thing is my 4' buckst is not heavy enough to weight the front end down. When I unpin the loader I am supposed to use the valve to lift the bucket and that will raise the back end up to drive out. Well my bucket doesnt weigh enough so when I try to do that the bucket still goes up. I had to find a chunk of concrete to put in it to weight it down. That did the trick. The next thing was my hoses were all zip tied up to make them short and out of the way, which is nice, but I had to cut the zip ties to get enough slack to drive out and still be able to use the hydraulics on the loader. As you drive out can extend the bucket up and the front comes down to make a kick stand. It took about 30 minutes to get the thing back on hopefully it will getto be a quicker process the more I do it. All in all it was a pain.
late
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
Hester 1206 10' V Disc (A50121)
Hester 1206 10' V...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
1996 John Deere 7210 (A50120)
1996 John Deere...
