1450 Front Hanger Assembly Falling Off
   / 1450 Front Hanger Assembly Falling Off #1
cubby1450
Cub Cadet 1450 hydrostatic
Parts and Diagrams for Cub Cadet 44A 44", 50A 50" 3 Blade Deck
Mule drive belt broke and shredded into tiny little pieces. After getting a new belt installed and running it for about 100 feet, I noticed the front hanger assembly was falling off the mower. I disconnected the belt and pulled the two spring loaded bars out of the back of the top of the mowing deck to drop the deck loose. The deck was a little crooked from the front hanger assembly coming off.
I managed to get it lined back up and put the belt back and pushed the front hanger assembly back into place. I ran the mower for about 50 feet and the same thing happened again. How do I keep it from coming off?
Thanks,
   / 1450 Front Hanger Assembly Falling Off #2
there should be a spring loaded handle under the nose of your cub that keeps the mule drive in place. on my dads 125 it stays where you put it, open or closed. make sure that you have that lever in the position where it is holding the mule drive in the slots.
Thanks. I thought it was, but apparently either it wasn't or it's popping out of the closed position. I'll give it a thorough look.
Thanks again.
   / 1450 Front Hanger Assembly Falling Off #4
On our 1440 I had to wire up the hanger when the spring broke. Sure I could have gotten a new spring.
Giyi 27" Mixing Bucket (A53316)
Giyi 27" Mixing...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
New Holland L555 Skidloader (RUNS) (A50775)
New Holland L555...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2019 JLG 2632ES 26ft Electric Scissor Lift (A55787)
2019 JLG 2632ES...
58" 3pt Snowblower (A50775)
58" 3pt Snowblower...
