1440v loader hyd.
/ 1440v loader hyd.
Yes..thats where i got them......i will try again just to be sure..... thanks
/ 1440v loader hyd.
I did it again with the same results...any ideas ?? could it be set that low ?? i wont have time to check anything el /forums/images/graemlins/confused.gifse until tues.. got to get to work ...while its not raining...thanks for all the help /forums/images/graemlins/confused.gif
/ 1440v loader hyd. #23
You need to do the check at (I think, old age) 2600 rpm. What rpm did you use for those numbers?
/ 1440v loader hyd.
it was at 2600 rpm...i may be doing somthing wrong ?
/ 1440v loader hyd. #25
When you have the rpm at 2600, hold the loader valve to the lock. Then it will build pressure. If you don't do this all you are doing is testing the flow resistance in the system. Sorry that I forgot to mention that.
/ 1440v loader hyd.
ok ...but what do you mean about the lock.....???? i promise i am not as stupid as i seem..... /forums/images/graemlins/grin.gif and i thought i knew alot about tractors.... my dad used to say : Thats what i get for thinking : thanks
/ 1440v loader hyd. #27
What I mean by the lock is to push the joy stick alway to the right or left and hold it there.
/ 1440v loader hyd.
ok ..i will try that tomarrow....should i just hold it until the gage stops moving ?? sorry for all the questions.....
/ 1440v loader hyd. #29
No problem with the questions, just hope that I can help.
Yes, just hold the stick and you will see the gauge move up. Post with your results.
/ 1440v loader hyd.
well i finally got it checked ...the gage peged at 2100psi...i was afraid to hold the valve locked to long for fear of busting a hose..do you think that is accecpable pressure ??? thanks Bruce
/ 1440v loader hyd. #31
That pressure is fine. It is really close to the specked 2130. If you hold the valve open, is fine on the hoses, what happens is the relief valve opens.
/ 1440v loader hyd.
Jerry ....Thanks for all your help...i learned alot.....Bruce
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
Butler MFG Water Tanker (A63688)
Butler MFG Water...
US ELECTRICAL TOOL CO.-500B BALL BEARING GRINDER (A64280)
US ELECTRICAL TOOL...
2000 John Deere 7410 (A64119)
2000 John Deere...
