1440 Hydro problem
/ 1440 Hydro problem #1
coolmac
I bought the 1440 2 years ago and changed all fluids/filters.
All was great until yesterday, no forward or reverse after 2 min into the cut. The Briggs engine running great and doesn't load down at all.
I checked driveshaft, linkages, fluid level and hydro relief valve wasn't disengaged. All good. I pushed to the garage, that sucked.
What was odd, I could push the tractor with the hydro relief valve engaged or disengaged ? The tractor just makes a light clicking noise.
Did the hydro die, relief valve sticking, any other checks?
/ 1440 Hydro problem #2
Hello coolmac, and welcome to TBN.
Sorry I don't have an answer for you, but perhaps if you moved your post to the Cub Cadet lawn and garden (L&G) you might get more responses...
Good luck!
I posted in lawn and garden.
Replaced the Fram 2844 hydro filter with a CC filter and all is good.
The Fram must of clogged.
Back to mulching leaves. . .
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
Tennant 5680 (A64127)
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2009 STRICK 53X102...
CHEETAG CH-5 BEAD SEATER (A64276)
CHEETAG CH-5 BEAD...
