1440 Amp light help needed
/ 1440 Amp light help needed #1
Frosty2
Hammond,IN
94 Cub Cadet 1440
As I went through the maintenance items and made sure the PTO and everything worked I noticed the AMP light came on when the PTO was engaged.Purchased a service manaul hoping to find info on what could be causing this.That turned into another story.Manual (772-4166) doesn't mention my 1440 anywhere.Called the service center and after a half hour of being switched from person to person learned that the 1340 model is same as 1440.Go figure.The service manual doesn't have much info on the electrics.Guess you need a motor manual for this.So I used my 1440 w/mower deck today for the first time since I purchased it,running it for over an hour w/the light on.Wow,does this machine work well.Imagine my surprise when it restarted easy when finished,I expected to have a dead battery after this torture test.Noticed the light also came on w/PTO off and headlights on also.I'm leaning towards a false warning light.Anyone know of a way to check for this.I realize I need to check the stator and then the regulator.Any help in what amps or volts this unit should be producing would be a great help.Owners manual states that the system is a 15 AMP set-up if that matters.This is driving me crazy trying to figure this problem out.Thanks in advance for any help w/this.
/ 1440 Amp light help needed #2
You need a voltmeter to clip on the battery. If the voltage reads 13.5 to 14.5 volts while running the alternator is working fine.
Bob B.
Thanks Bob for the reply.Battery showing 12.21 VDC .Checked stator (2 yellow) 26.9 VAC. Checked other wire (red) from Regulator to ground, .09 VDC.All of these results were with throttle wide open.I'm leaning towards bad regulator.Another thing I should have mentioned is the machine is using a bigger automotive type battery if this matters.Thanks again,Dave
/ 1440 Amp light help needed #4
12.2 volts is definitely not charged. Battery should be 12.6 when fully charged and everything turned off. I think you're on the right track.
Bob B.
Amp light update.Regulator was the problem.No Amp light with PTO and lights on now.Mowed 1hr today w/nothing but good results.The more I use this machine the more I'm glad that I purchased it.Thanks for helping this newbee out....
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
