MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,624
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
But lake Michigan levels are at an all time low.
MossRoad said:But lake Michigan levels are at an all time low.![]()
IrTxRx said:To summarize thus far:
used CUT BB vs PT BB -- CUT BB (for me)
Wheel trencher -- Anyone have any experience with this thing? is it basically the stump cutter with angled tips to make the trench a little wider?
Mini-hoe -- don't leave home without it
Grapple vs 4n1 -- Grapple and consider a potatoe digger also, I just don't see $400 when I look at the picture of this thing???
I expect to buy within the next 60 days and cannot wait
Thanks again
Thanks again
IrTxRx said:JJ,
I need to run some poly pipe for animal water as well as some 1.25" sch 40 water pipe for lawn watering. I do not think a regular trencher would work (have never seen any contractors using them in this area). Given my terrain and latitude, do you think the wheel trencher is the best way to go? Will it cut through my limestone/caliche "soil" ???
Thanks
KentT said:You may want to consider JJ's recommendation on using the stump cutter for trenching. In Texas, your frost line is non-existent so burying things 6"-8" would be sufficient to prevent freezing...
Then, you would have the stump cutter for other uses -- someone here suggested using it like a large circular saw to cut up tree trunks into smaller pieces for moving them with the grapple bucket. If you could somehow turn the cutting wheel 90 degrees, you could even use it like a BIG weed-whacker to cut down saplings etc. -- don't let the safety police hear that one though...![]()
IrTxRx said:Thanks Kent,
Forget the CUT and 3 point attachment problem. I love the idea of a tree chunker and brush whacker. But, my primary use (as currently envisioned) will be pipe trenching. Is the hole the stump cutter digs WIDE enough for 1.25 - 1.5 inch pipe??? Is 6 inches deep enough to prevent stuff from working out of the ground and for other safety/purposes???
