1430 Hydroback cable
/ 1430 Hydroback cable #1
menchhofer
Did several searches and cannot find posts on the 1430 hydroback cable. Seems as if there was another supplier less expensive than Powertrac. Anyone remember?
Thanks
/ 1430 Hydroback cable #2
Thanks
You can remove your cable and take all the measurements and probably order from a supplier but being an infrequently replaced item, I find it's easier to just order from Power Trac. That being said, you could look at McMaster-Carr site and search for push pull cables.
/ 1430 Hydroback cable #3
Hi Menchhofer: I did post something back in 2009 or 2010. I designed and ordered several from: https://www.midwestcontrol.com/ go to cables on their website and select design you own down at the bottom of this page: https://www.midwestcontrol.com/series.php?id=200
It did not take very long and I used the good cable (series 40, I believe with the nylon inner guide) - back then I got two for the price of 1 from PT. I had bought several from PT but this made it easy to get a spare and then, with one on the shelf, they seem to last longer!
good luck
Don
Thanks you guys. Appreciate the help.
