1430 1 year report - long
/ 1430 1 year report - long
Hmmm???
i'll have to do a little experiment and get it in pucker mode and see what happens.
/ 1430 1 year report - long #22
I frequently raise both front tires off the ground with the bucket curl and back-drag ball diamonds with just the back tires pulling. The front tires will spin slowly as the backs pull me along. If I get too much material under the rear lip of the bucket it will usually stop the tractor and spin the rear tires. This is on a PT425.
I do the same thing when back-dragging snow with the plow in winter.
/ 1430 1 year report - long #23
Here's a video example of it, only going forward.
http://www.mossroad.com/PT425Videos/PT425_BigBite.WMV
You can see that as I push into the dirt, I am in float mode. The bucket bites into the soil and the front tires lift off the ground and spin while the rear tires want to push the tractor up and over the lift arms. I take it out of float, lower the front tires a bit and continue.
Here's another example. I'm moving a huge log with the right rear wheel off the ground. I didn't even know it until after a few feet. :)
http://www.mossroad.com/PT425Videos/PT425_logs02.WMV
/ 1430 1 year report - long #24
Dang, you're tall. Any goose eggs from the canopy? :p
/ 1430 1 year report - long #26
MR- thanks for clarifying. I'm not sure that it would have occurred to me to look for the bushing!
Well, OK, perhaps when the blades weren't spinning well...
All the best,
Peter
/ 1430 1 year report - long #27
Well guys, today I'm getting my chance to check out a 1430 today.
Apparently the guy that owns a 1445 in Mayville also had a 1430 so I might try both, you know, do a comparison.
I'll have some video later.
I can't wait!
(Also check out my new avatar!)
/ 1430 1 year report - long #28
Okay so I didn't get to try a PT.
This is what happened; Called Ted, his wife or someone answers. "Is Ted there?" "No he passed away" :eek: :(
That was weird and sad at the same time. Sad because he died and weird because I wasn't expecting it.
Be yesterday was Ok. I got to look at a Toolcat, again :D
/ 1430 1 year report - long #29
So, you express your condolences to widow and ask, "Will you be selling the Power Tracs?" ;)
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A59228)
2025 JMR 40in...
(INOP) 2023 TAKEUCHI TL12V2 SKID STEER (A60429)
(INOP) 2023...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
TEST YOUR BID BUTTON! (A60430)
TEST YOUR BID...
159118 (A60430)
159118 (A60430)
