1428 vs 1528
   / 1428 vs 1528 #1
Ronster
CT
John Deere 2520, John Deere X739, Kubota U27-4, Kubota RTV 500
I've found a 1428 for $1200 less than a 1528 , but the dealer is 4 hrs from my home. The only one I've seen up close is the 1528. Can anyone give their thoughts on the differences of these two machines? By the way, the dealer says that I can have the new style 1520 loader put on the 1428. Is this right?
   / 1428 vs 1528 #2
The 1520 loader will fit the 1428. The main difference on these models is the platform on the 1528 has been cleaned up, new style seat, larger fuel tank, folding ROPS and the styling of the sheet metal has changed.
   / 1428 vs 1528 #3
One major difference is the 1528 now has the gear shift on the fender instead of below the seat. I think the fender shifter is much better. /forums/images/graemlins/grin.gif
   / 1428 vs 1528 #4
is that 1428 hst ? is the price qoute 13800 on post (1528$$) ?i would try to get more then 1200 less . and also look into the 1428 hst gear range linkage to the trans . the manufact. bulletin on the linkage . be sure that it is replaced with the ugrade. had my 1428 replaced before i received it.i was at the dealer when the work was being done.today i used my fel quick pin hitch ,it took less than 1 min to hook up the fel bucket /forums/images/graemlins/laugh.gif
   / 1428 vs 1528
I got a quote of $11,500 for the 1428HST and $12,700 for the 1528. The FEL is $3600.$200 to up grade the 3pt links.
   / 1428 vs 1528 #6
$ 11500 for a 1428hst is a good price.that what the 1528 gear model is going for. $3600 for the fel is the going rate. $12700 is a fair price also. 2 MF dealers my way want $13500 for the 1528 .
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
1275 (A50490)
1275 (A50490)
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
