1428 low engine idle
/ 1428 low engine idle #1
SJC1428
My 1428 just started running weak maybe good engine power to about 1300-1500RPMs after that it sounds like it is starving for fuel. I have tried to bleed the air out the system at the fuel filter, injection pump and at the injectors.
The first two appear to be bled okay but I get just a little bit of fuel at the injectors. I would think that I should see a fair amount of fuel at pressure at the injectors. also I only have 80hrs on this machine.
TIA for your help
/ 1428 low engine idle #2
Is it possible that your filter is dirty??? Or anyone touch your fuel valve that is close a little?? Is it possible you hit anything that compressed a fuel line?? Keeep investigating, good luck
Roger, I checked the fuel filter and that didn't work so after some thinking, I haven't had to troubleshoot in awhile, I pulled the air filter and she rev'd right up so it looks like a new filter is required. Now if I can find one other than the dealer.
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
1979 AM General 6X6 Truck (A65563)
1979 AM General...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
SELF-PRIMING CENTRIFUGAL PUMP (A65643)
SELF-PRIMING...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
