1428 low engine idle
/ 1428 low engine idle #1
SJC1428
My 1428 just started running weak maybe good engine power to about 1300-1500RPMs after that it sounds like it is starving for fuel. I have tried to bleed the air out the system at the fuel filter, injection pump and at the injectors.
The first two appear to be bled okay but I get just a little bit of fuel at the injectors. I would think that I should see a fair amount of fuel at pressure at the injectors. also I only have 80hrs on this machine.
TIA for your help
/ 1428 low engine idle #2
Is it possible that your filter is dirty??? Or anyone touch your fuel valve that is close a little?? Is it possible you hit anything that compressed a fuel line?? Keeep investigating, good luck
Roger, I checked the fuel filter and that didn't work so after some thinking, I haven't had to troubleshoot in awhile, I pulled the air filter and she rev'd right up so it looks like a new filter is required. Now if I can find one other than the dealer.
Aluminum Hog (A65583)
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2010 UKNOWN GOOSNECK PIPE TRAILER (A65643)
2010 UKNOWN...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
18ft Bumper Pull Trailer (A65640)
18ft Bumper Pull...
