1401 fuse block cover
   / 1401 fuse block cover #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
I have a 1401 that I use for all my yard and garden work. I try to keep it in excellent shape . I have lost the plastic cover for the fuse block. I was wondering if anyone in Yanmar land might know where I might purchase one? Thanks in advance.
   / 1401 fuse block cover #2
If you have a parts manual, you can see if a U.S. Yanmar dealer can get you one with the part number. Parts like that tended to be used on multiple tractor models, and even on U.S. as well as Japanese models.
   / 1401 fuse block cover #4
If it is the same part as that on a 1510, then it is the same as my 1301 as well. My 1510 and 1301 parts manuals don't show the cover separate, only the entire fuse panel with fuses and cover. The part number is:
194440-52400
JOHN DEERE CP24 ASPHALT PLANER (A60429)
JOHN DEERE CP24...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED AGT INDUSTRIAL STSD10 SEEDER (A60432)
UNUSED AGT...
