140 Farmall
/ 140 Farmall #1
tunkin
Waycross,Ga.
140 Farmall
I have a 140 Farmall that the lift whines all the time and will not lift my disc harrows but a few inches.
Anyone have any ideas?
/ 140 Farmall #2
check yer fluid.. see if it's low, or foamed.. or wet.
would it normally lift these.. or are they just too heavy?
whines are commonly relief.. though could be cavitation / input restriction.. etc.
/ 140 Farmall
Fluid is fine,it should pick these up with no problem.I am just hoping it is not the pump,those little jokers are $600.00 or better
/ 140 Farmall #4
The first thing you gotta do is change the hyd. FILTER!---no body ever services them and after some use they get clogged!---If you have bad fluid in there the filter will plug after a few mins. runtime again, so clean the system and refill with new fluid all at the same.---may have to do this a couple times to get it really clean.
next step would be to check the control valves for proper adjustments.---the pump whine sounds like its not getting fluid, so start with filter and fluid change! thanks; sonny 580
/ 140 Farmall #5
What year is it because we have a 140 farmall and the hydraulics work good
/ 140 Farmall
I really do not know what year it is,mine worked good for a couple years and then started going bad.
/ 140 Farmall #7
what about rebiluding it. the last our 140 got rebilud was 1979 and from 1979 it runs great.
/ 140 Farmall
I have thought about doing that,proably gonna have to
/ 140 Farmall #9
These tractors were produced for 21 years--1958 (year I was born) through 1979 (year I was married)--and the serial number, found on a plate on the left side of the bell housing, identifies the year of manufacture (see pasted chart). I can only lift my 16-disc harrow a few inches off the ground. Remember that although these are tough little tractors, they're only about 20 hp and 2wd. That's not very much power in lifting an implement weighing 500-600 pounds. Instead of lifting the disc and carrying it to the tillage site, I just let it touch the ground and let the discs take part of the weight.
1958: 501
1959: 2011
1960: 8082
1961: 11168
1962: 16637
1963: 21181
1964: 25387
1965: 28408
1966: 31285
1967: 34818
1968: 37352
1969: 39906
1970: 42300
1971: 44424
1972: 46605
1973: 48507
1974: 50720
1975: 54273
1976: 57773
1977: 60839
1978: 63111
1979: 64544
2004 John Deere 4720 (A60462)
2004 John Deere...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
