14 hp B&S OHV Compression Release
/ 14 hp B&S OHV Compression Release #1
bjr
Eastern WA
Jinma JM354
I'm little disgusted with B&S. There repair manual barely addresses the compression release little alone mention that it's a starter eater if it goes out. I fried one starter and was going for the second. I could get the engine to spin just fine with plug removed, with plug installed it just tried to turn but couldn't. I had no idea of a compression release and the local shop (a major regional distributor for B&S) didn't have a clue and just wanted to keep selling me starters. There at the least could more reference to compression releases on starting trouble shooting, so a fellow would know. I want to know if there is a extra heavy duty starter I can buy and not have to worry with a broken spring on the camshaft compression release. I would consider replacing the engine with a different model that didn't have that little time bomb on it. What engine would be a good replacement? bjr
/ 14 hp B&S OHV Compression Release #2
Just read this & am wondering if you found out if the compression release was indeed your problem? Valve adjustment is crucial on these OHV engines & if they aren't right, they will give the same symptoms that you described.
Ford Model 8N Tractor (A66285)
Ford Model 8N...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
