14 hp B&S OHV Compression Release
   / 14 hp B&S OHV Compression Release #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I'm little disgusted with B&S. There repair manual barely addresses the compression release little alone mention that it's a starter eater if it goes out. I fried one starter and was going for the second. I could get the engine to spin just fine with plug removed, with plug installed it just tried to turn but couldn't. I had no idea of a compression release and the local shop (a major regional distributor for B&S) didn't have a clue and just wanted to keep selling me starters. There at the least could more reference to compression releases on starting trouble shooting, so a fellow would know. I want to know if there is a extra heavy duty starter I can buy and not have to worry with a broken spring on the camshaft compression release. I would consider replacing the engine with a different model that didn't have that little time bomb on it. What engine would be a good replacement? bjr
   / 14 hp B&S OHV Compression Release #2
Just read this & am wondering if you found out if the compression release was indeed your problem? Valve adjustment is crucial on these OHV engines & if they aren't right, they will give the same symptoms that you described.
Pair of New 700/40-225 Alliance Tires with Rims (A53473)
Pair of New...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
Two Post Car Lift (A50120)
Two Post Car Lift...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
