14.9-24 vs 17.5-24 tires
   / 14.9-24 vs 17.5-24 tires #11
Just using it around the house - plugging yard, sowing grass, mulching trees, scraping driveways
You're going with the R4s aren't you........
I hate them, never again, never never never. Turfs around the house are good for 90% of what I do.
   / 14.9-24 vs 17.5-24 tires #12
What size tires are on it? What bolt pattern?
David from jax
I am not sure. I think its the 7 14, they have 6 lugs. Not sure the pattern diameter. I am not very familiar with tractor wheels and tires so don't be shy about oversharing information with me :)
   / 14.9-24 vs 17.5-24 tires #13
If you have a soft sidewall and the fatter/larger air volume, I prefer that and run them at as low an air pressure as I can get by with for riding comfort. Between Fescue isolated plants (clumps) and Houston Black Clay cracks (you could loose a front tire in) summer time travel is a bummer. Any help I can get I'll take it.
   / 14.9-24 vs 17.5-24 tires #15
Those same tire size options were available for my Yanmar LX. I went with the AG tread for better traction in clay soils and snow conditions.
Something to consider with an open station tractor, can you reach the three point lift lever from outside the tractor? With the 14.9-24 Ags, I can stand beside the tire and just about reach the lever, this is handy when hooking up attachments. With the wider 17.5-24 R4s, I could not reach the lift lever from outside the tractor.
   / 14.9-24 vs 17.5-24 tires #16
Sorry to bring up an old post but tractordata says my JD302A came with 14.9-24 but it currently has 17.5L-24. Does that mean a previous owner has put different wheels on my tractor or will both tires fit the same wheel? Also, I have wheel weights, if the same wheel will do either size of tire, will having wheel weights make one size better than the other?
   / 14.9-24 vs 17.5-24 tires #17
The 14.9 uses a 13" wide rim. The 17.5 uses a 15" wide rim.
   / 14.9-24 vs 17.5-24 tires #18
If the tractor is 4WD,, the tire height must be correct,,
or else,, there will be more posts on why you can not get the tractor out of 4WD,,, :eek:
Actually the front and rear must match. If the stock rears are 36-inch diameter, and the fronts are 22-inch diameter, you have to maintain the 22:36 ratio as you change tire sizes. If you increase the rear to 39-inches the fronts need to go up to 23.833 or something close to that. And, that is where the problems can begin. The rears can change so long as they fit in the fenders. The fronts, since they turn, can have clearance issues.
1683 (A58375)
1683 (A58375)
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
Case Titan 3530 (A56438)
Case Titan 3530...
2019 WANCO, INC LIGHT PLANT (A58216)
2019 WANCO, INC...
2019 Takeuchi TS80V-2 Rubber Tire Skid Steer, PIN# TKV80201102, Deutz Diesel Engine, Joystick (A59076)
2019 Takeuchi...
