135 Massey Clutch Inspection cover plate
   / 135 Massey Clutch Inspection cover plate #1
CharlieDelta
Australia
Massey Ferguson 135
I have bad leaking around the clutch inspection cover. I went to tighten it up and found to my horror a piece of thin Aluminum/Aluminium sheet held on with Silicone. It looks like foil its so thin.
I will try and get a cover. I might try and making one up in the mean time. Anyone have the dimensions between centers for this inspection cover plate?
I cant seem to find the part part number for this clutch inspection plate
   / 135 Massey Clutch Inspection cover plate #2
There should not be oil in the clutch housing, probably a seal failure. Is it engine oil or transmission oil?
   / 135 Massey Clutch Inspection cover plate #3
If the shape of the casting matches the pic of the plate then the part number for the plate is:180482M1 and the gasket is 180481M1
Available from here: Housing
Quite possibly the oil is coming from the rear main seal...very common on the Perkins.
353901X1 4 Screw Unc Up to Serial or Engine Number 400000 Setscrew 5/8 x 1. 1/4 Unc (Din 933) Grade 8.8
354441X1 4 Screw Unc From Serial or Engine Number 400001 Setscrew 5/8 x 1 Unc (Din 933) Grade 8.8
PALLET OF VIGORO HD FABRIC & GARDEN STAPLES (A51248)
PALLET OF VIGORO...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53472)
Chevrolet C8500...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
